Runtipi WebGUI not loading - 404 error
Hi!
I have some problems getting into Runtipi. If I go to the IP address, I get a “404 page not found” error. It was working once and I installed, for example, ChangeDetection. That still seems to run because I get email notifications about changes on monitored webpages.
I am a beginner in all this, so I did some screenshots to help me explain. Something seems to be wrong, for example I cannot run the command ./runtipi-cli debug.
Oh, as a new user I can only upload one image. I uploaded all 4 images here:
Screenshots on imgur.com
Anything I can do?
Thanks in advance!
Where is runtipi installed? I can’t run ./runtipi-cli unless I am in the runtipi folder. Maybe try that first.
Does your root file system have enough HDD space? Runtipi needs free space to load.
Not sure whether running Runtipi in an LXC is adding complexity, cos you’ve got an LXC running a Linux distro, running docker, running runtipi.
